hopkinwfg Posted June 11, 2025 Posted June 11, 2025 Hi peeps am concern about slight wobble on my H150CC bridge pole piece as i actually took out and back a few times now i realised even with the pole piece insert 2/4 (estimate) in length it wobbles abit as i gently rock the pole piece unlike the other side it was hard solid... So much that i have to to screw the pole piece till the end and its rock solid.... would there be a concern as i think the intial few thread on the body perhaps has worn... but visual check from the surface of the hole still look ok not enlarged thou lol.... Is this normal due to engineering factor when they taper the screw holes for the pole piece ?
Spectrum13 Posted June 11, 2025 Posted June 11, 2025 Suggest using an additional thumb screw to lock it to the top to prevent more rocking that could gubber the threads. Rocking torque will mess up your intonation. Best solution, replace both screws with a Faber steel studs and bridge and lock it down tight.
hopkinwfg Posted June 11, 2025 Author Posted June 11, 2025 9 hours ago, Spectrum13 said: Suggest using an additional thumb screw to lock it to the top to prevent more rocking that could gubber the threads. Rocking torque will mess up your intonation. Best solution, replace both screws with a Faber steel studs and bridge and lock it down tight. It just became stable when i screw down the pole piece straight to the bottom end.... It still has the pinnacle API locking on the abr1 bridge Am not sure if i do want to try fixing it with a wooden dowel and retap the threads.... so far the pole piece are stable as solid being screwed down to the bottom end...
