Posted (edited)
For those of you that have played/owned both the Standard and Custom Core H-535, is the Custom Core model a noticeable upgrade over the Standard? The Standard is already a very high-quality guitar.
I've seen some people say yes (which I'd expect), but have also seen a few people say they actually preferred the Standard model for whatever reason.
Curious on people's thoughts.
Edited by AllThatJazz
Posted (edited)
I think I saw your post on Facebook asking the same question.
Here's my opinion..  Both the custom core and standard line are made in the same place, using the same tooling, from the same selection of woods by the same people.  Quality control is the same for both.  So other than physical differences (pickups, hardware, and inlays), ask yourself what are you really getting out of it?
I have a 2023 standard line H150, it heavy compared to a custom core, but a 535 won't have the same weight variance.  Now that both CC and Standard use in-house build pickups....  the lines of demarcation between both models is even blurrier now.
If you want the blinging, nicer wood package, get a Custom Core.  If you want a solidly built, high quality guitar and save a bit of coin, get a standard line.
Edited by DetroitBlues
They both use in house pickups, but the CC's are alnico III with a vintage tone, and the hardware and tuners are better. Also different neck shape and better looking headstock and inlays on the CC. And probably a nice, more select, piece of mahogany for the neck. If it were me, I would play both and see if the differences are worth it.
  • Upvote 3
Posted (edited)
if money was no object, I would go for the Custom Core for the 50's neck carve alone. That's just personal preference. I am sure the standards are very nice in their own right.
Edited by Jazz2Punk
If money were no object,  I would get the CC but probably with something closer to the standard carve neck.
My fingers aren't that long, and fat necks aren't necessarily the best thing.   I'm sure I could talk Pete into carving one that fit me... for the right price.   And it's not just the size,  it's the shape.  V necks aren't good for me.   Wide and flat isn't good.    I like the edges to have some roll to them.   A sharp edge on the fingerboard turns me right off.
Can an average Joe like myself get a thicker neck carve on a standard H-530 for an upcharge or is that just for those on the inner circle? I would love to have that option.
Posted (edited)
That's something you might want to talk about with Mike at Heritage.    They have a process, and it probably depends on how much of an upcharge it would require.  Under the CC portion of the website they mention their "bespoke" program.
I don't know where you live, but if there is a dealer anywhere close, you should check out the current line.   I didn't feel like the necks on the Standard II guitars were toothpicks!   The couple I picked up were comfortable.   I've felt much thinner necks.    The 530 I bought in '25 is the original Standard line, but the neck isn't really any thicker than my 2005 535.
I hear all these comments about thin and thick necks, but for me, shape is FAR FAR more important than how thick it is.    My 2014 Vintage '54 Strat has a baseball bat for a neck, but it's comfortable.   My 74 Guild S100 is much thinner but I've played that for years!    I've tried several PRS necks that were thin and were painful to play.   I can pick up a guitar and can tell within 10 or 15 seconds if it's right or wrong for me.
And if cost were no object,  I would just fly  up to Kalamazoo on a private jet and visit the factory.... or else drive my Ferrari up there.   Unfortunately, someone else won the $700+ million Powerball, so there's no private jet or Ferrari in my future!
Edited by TalismanRich
  • Upvote 1
If I were in your shoes, looking for a specific neck carve, I'd make the request through one of the larger, high volume dealers (i.e. Dave's Guitar Shop, Wolfe Guitars, etc.).  They might be able to order a 'special run' of '59 neck profile' H530's, or see if they have one at the factory.  Heritage dealers have much more sway than a single customer seeking something unique.  Good luck!
  • Like 1
I have both and they're equally good. The standard one is in osb finish with factory Seth Lover pickups and it is an absolute killer instrument. I would just play them first.....with my eyes closed 🫣
  • Upvote 2
I will try that when I have the funds together, thank you!
I hadn't noticed that on the site. Thanks for the heads up!
  • Upvote 1
  • 2 weeks later...
Posted (edited)
Spent an hour Friday comparing an H-530 standard with the custom core model I had played previously. Despite the public flogging I got above  from Rich 😅, I'm going to have to double down on the 50's style neck carve being the one for me.
Both guitars were very nice and the price on the standard is much more attractive. That said, I'll just have to keep saving and keep an eye out for a used custom core that I can eventually afford.
Not sure if the 60's vs 50's neck carve matters to the OP or not but it is worth considering if you are extremely particular in this area. Overall, the custom core model definitely had a more premium vibe to it but I'm not sure the cost difference between the two models is justified. If the standard had the 50's neck carve, I wouldn't even be considering the custom core.
The standard 530 sounded just as good and the cost savings is substantial. I know the OP wasn't asking about the 530 but I'd imagine the differences to be somewhat similar with the other Heritage models as well.
Edited by Jazz2Punk
:violent1:
I know that Josh like a thick neck.   I've felt the necks on a couple of his guitars over the years and they were quite "beefy"!   There are days when I wish I had long fingers.    I might be able to play some of those chords that the pros do!    And there's no way I can do the thumb-over-top bass stuff.
