I recently purchased an older H-535 that is really interesting. I was thinking the community might want to help unravel some of the mystery.
The serial number starts with AE, so this is likely a 2014, but the seller told me this was a 2006. I think he believed that because the model number on the hang tag is H-535.'06. Any ideas on what the '06 in the model number designates?
There are no screw holes for a pick guard, so it definitely left the factory this way. There is also no label or glue residue for a label inside the body. There are no indications of this being a factory 2nd, so I'm thinking this was a special order.
Here are some more details on the specs. The bridge is a Gibson branded ABR-1 and the stop bar has a set screw, so I'm thinking it might be a tone-pros. The part number and date stamp on the pickups show they are Duncan Seth Lovers from 2015. This may be an owner mod or it may be that the guitar was serialized in 2014, and not completed until some time later with newer factory original pickups. The seller believes that this was built for or by an employee for his personal collection. This theory was based on who the previous owner was and how he came to own it. I'd prefer not using anyone's real names to help protect their privacy, but this is another reason why I think it was a special order and a possible explanation for the newer pickups. I can add some pics shortly. I need to reduce their size. Right now they are too big and exceed the 1.5M limit.
I have emailed Heritage to see what sort of documentation they may have on it, but I also thought it would be an interesting conversation to share with the community. Anyone want to chime in with thoughts?
Pics?
It doesn't sound quite right to me.
I do own a special order H150 from 1998. It was a dealer special order, they made a run of them, maybe a few runs of them. It is a standard H150 but it came with SD 59 pickups and a Nashville tune-o-matic bridge and a zinc stop bar, instead of the typical Schaller pickups, bridge and tail at the time.
But it bears a regular serial number and it has the normal sticker under the control cavity cover.
  • Like 1
46 minutes ago, nuke said:
Pics?
Agreed. I would think this doesn't sound quite right either, but as you can see in the pics, this is was it has. Maybe they did something different on the H150's? The pickups could be a later mod and honestly I'm trying to avoid pulling the pots out to check the codes. That is such a pain on these and with my luck I'll go through all that just to find the solder covering the code! LOL.
AE definitely means that it's a 2014 not a 2006.  In 06 they were stamping the serial number and they started with W  ( have a 2006. On mine, the W is above the number.  I think they had to get a new stamp as the old one was wearing out).   They didn't start hand writing numbers until later.   It's hard to say what the '06 designates, and don't know they'll have any special info regarding it's specs.   Sometimes Ren or Jim would remember special orders, but if you built a few thousand guitars over 25 years,  you wouldn't remember every one.   I don't know that they kept a computer database, although by 2015 they may have well converted.
If I remember the first two numbers are the days working backwards from Dec 31, and the last two is the number of the guitar issued that day.    That would make it the second guitar of  Monday Oct 27th 2014.
The Seth Lovers could easily been owner changed, or factory installed.   It's also possible that the paper label either wasn't installed or came loose.   Still, they are of a close date to the guitar serial.
I don't think it would be worth the time to pull the pots just to look at date codes.
  • Like 2
That is a bit odd with the '06
the serial # looks like AE 06502
So maybe it refers to the 06 in the serial
Hardware gets changed all the time. So who knows what the gtr left the factory with
Congrats that is a nice 535!
  • Like 1
Thanks! It is a sweet one and plays like a dream. I was lucky to stumble on it especially since it was shipped from out of state. This is my 3rd Heritage and it is by far the best.
Posted (edited)
The pickups are little odd. Usually, the Seth Lover set has a smooth base plate, a sticker in the middle with a rubber stamp serial number, and the blue "Seth E Lover / Seymour Duncan" signature stamp over it. Then there's the little model number and date sticker by the leg.
If you look at the photos here at Sweetwater, they have an image of a 2016 Seth Lover
https://www.sweetwater.com/store/detail/SH55n4NKL--seymour-duncan-sh-55n-seth-lover-4-conductor-pickup-nickel-neck
Usually what they look like.
Looks like you have a bridge with the embossed "Seymour Duncan" logo pressed into it, no rubber-stamp sticker and no blue signature. But the neck (fuzzy background) looks more like I'd expect.
I think the H-535 '06 is actually "106".  Which makes sense if it was part of special run or something.
Perhaps the internal sticker has been lost to the winds. It is just a paper decal, a dose of humidity or bad luck might loosen it. Or someone picked it out, or who knows on a 9-year old guitar.
I think you got one someone's mildly modified.
The blonde 2001 with HRW pickups I own, I found a couple of years ago at a shop that had it marked as a 2020 for some weird reason. It was pristine, with the original Schaller hardware. It had "the sound" one wants from a 535. Had to have it. I later found it had the waviest fretboard to escape the factory. Neck perfectly straight, fretboard like a roller-coaster, though all the frets were level. Some were brand new tall, and some were leveled down to .027" tall. Eventually I pulled all the frets, leveled the rosewood, then refretted it myself with medium jumbo, which means the nibs had to go, then put Faber hardware. So, the moral of that story is you never know what someone does to them in the field.
What counts is how good it is. :)
My 98 H150 I bought used when it was 2-3 years old, from the original selling dealer. (Buffalo Brothers, who were a big Heritage dealer long ago). They ordered the run with this spec, and took this one back in trade from the original purchaser.  The SD59's in it are OEM ones that SD sold to manufacturers back then. No stickers and a little different stamping on the back. So definitely original.
Edited by nuke
Posted (edited)
100% right on the pickups. I noticed that oddity also. Here is a close up of the neck pickup. Interesting observation on the ' vs 1. Never thought of that. Being hand written, that makes perfect sense. I heard back from Ren at Heritage. Unfortunately, they don't have the original build order so we'll never know for sure, but I think you are right about owner mods. Probably left the factory with 59s as they are more common and then swapped to the Seth Lovers later. One of these days when I feel adventurous I may pop one or two of the control pots out to see if the solder joints look original or not. For me, the history of this one is more of a curiosity thing than anything else. This would still be one of my favorite guitars of all time because it is just that good. You know every once in a while you notice something special the second you put your hands on it? Thats this one. I was very fortunate to stumble across it .
Edited by MikeJacob
typo
  • Like 1
Just curious if you can read the ohms of the pickups?
Something strikes me odd about the bridge, like maybe it just got a sticker.
I think SD keeps a database of the Seth Lover pickups and can recall the DCR based on the serial number sticker on it.
I bet it sounds great with Seth Lovers. I had 59's in a 535 & changed them out, preferred unpotted pickups like Seths
1 minute ago, mars_hall said:
Haven't exactly followed this thread, but would say the bridge pup is either underwound or a neck pickup.
curious why you think this? Bridge is labelled SH55B = Seth Lover bridge
Neck is SH55N = Seth Lover neck
 I just checked this chart, I thought the bridge of a Seth was around 7.8 kohm but I guess I am mistaken: it says 8.1 kohm
https://www.seymourduncan.com/blog/latest-updates/pickup-comparison-chart
I must be thinking of the alnico ii pro, which is also a great pickup & one of my faves. I was recently messing with a set of those & the newer Slash signature pups, which are based on the alnico ii pro.
The original 50's Gibson pups weren't sorted by neck/bridge were they?
I thought they just grabbed pups out of the bin & neck/bridge were arbitrary, when they were assembled
  • Like 1
21 minutes ago, mars_hall said:
It appears the pup described as being a bridge Seth Lover has been opened and resoldered
Didn’t notice that before. Now that I look closer I think you might be right. Whatever the reason for it, still sounds amazing.
If the lead was too short and used in a different installation, a new one could be attached and any broken wires inside removed.  If you look at the braiding, at least in the pic shown, the braiding appears larger than the other
That clear tubing over the braid might be magnifying it, hard to tell IMO
For the record I just checked some other PAF style pups I have:
JS Moore: 7.3k neck, 7.8k bridge
Throbak Mick Taylor: 8.3k neck, 8.0k bridge
SD's according to that chart:
Seth Lover 7.2k neck, 8.1k bridge
alnico ii pro is 7.6k neck, 7.85k bridge
Doesn't seem wrong for Seth Lovers. They're usually around 8k ish.
I can't remember if they have the same impedance bridge and neck, or slightly more winds on the bridge. I was thinking they were the same. They're in the ballpark anyway.
The original PAF were the same, neck or bridge.
  • Like 1
Agreed. I don't doubt the pickups being Seth Lovers or not. I'm also confident they are genuine Duncans. Counterfeits don't sound as good as these do. I think one is regular after market production line and the other is OEM. Normal spec for the bridge is 8.1 - 8.3, so this one is still within the +/- 5% tolerance range.
  • Like 1
