nuke Posted February 6 Posted February 6 Anyone have direct experience swapping out a pair of Seymour Duncan 59's for a pair of Seth Lovers SH-55 pickups? I have a '98 H150 that was a special run with SD59's and standard tune-o-matic bridge/tail from the factory. It's also a lighter one, about 8-3/4 lbs. I've owned it for over 20 years now. Use it as a work-horse. The 59's are ok-ish, but I find them a bit aggressive and in general, I find they have in this, and many other guitars, a treble peak that's a bit harsh. It isn't overly bright, but it just has a peak in the wrong place to my ears. The original pots from Heritage were like the Norlin era-Gibson, 100k tone and 300k volumes, which darkened it up quite a bit. When a couple of the pots showed wear, I changed them to the more typical 500k and "50's wiring" since I like to roll the volumes up and down a lot while playing. I like the low-output PAF sound a lot, clear, articulate, bright but not harsh. A friend put throBaks in his Gibson R9 and that's the direction I'd like to go, but not $900 in that direction.
rwinking Posted February 7 Posted February 7 I have the Seth Lovers in my H-535 and I think you are right as far as them being smoother (If that is what you are saying?) especially on the top end. I have Dimarzio Anniversary PAFs in a couple of other guitars and they seem to have the same great tone and an identical high end. I am not sure that I could tell the difference btw the Seth Lovers and the Dimarzios. I love them both.
tsp17 Posted February 7 Posted February 7 To my ear, Seths are much better, but that’s just me. I haven’t done a direct swap, but when I’ve played similar guitars with Seths, i notice the musical and textural difference. Seths are more articulate, organic, smoother and just sound better for what i am looking for. You may have a different experience. I’ve had 59s in multiple guitars and only found them to sound great in one. Even in that one i swapped for a Benedetto B-6 and it was better for my use. That said, 59s sounded VERY good in that specific guitar (H575).
eljay Posted February 7 Posted February 7 fwiw, I have a 535 with 59s and one with Seths. The Seths are sweeter and smoother. I plan to sell the 59-equipped guitar but will keep the 535 with the Seth Lovers.
nuke Posted February 7 Author Posted February 7 Thanks guys, it is really hard to describe "tone", but I want that nice, bright, but not harsh top end. The 59's are good, especially with more gain/distortion. But I tend to play on the edge of break up most of the time and even sometimes quite clean and bluesy. The 59's seem to have a peak in the 1khz-2khz frequencyrange that grates a bit on my ears. I wish I had money for the ThroBaks, they sounded so incredibly sweet in my friend's R9. Now to find a deal on a set...
bolero Posted February 7 Posted February 7 (edited) check out Wolfetone Legends too. I have set in my '97 H150 & they are the bomb I like Seth Lovers as well Edited February 7 by bolero well 2
eljay Posted February 8 Posted February 8 (edited) On the subject of Wolfetones, I have a brand new set of Wolfetone Dr. Vintage, box never opened, that I'll sell for $190, shipped, lower 48. Dr. Vintage are similar to Legends. Edited February 8 by eljay 1
DetroitBlues Posted February 13 Posted February 13 (edited) Can't say I've swapped for them... But my 2023 H150 has SD '59 in the neck and bridge and my 1985 H140 has a SD '55 (Seth Lover) in the bridge. I gig with both of them. Tone wise, they both sound great, but I get a lot more feedback with a Seth Lover when I've got the gain up a little high. Either one works well for just about anything, just be mindful of the unpotted Seth Lover's. Pic for reference: Edited February 13 by DetroitBlues
rockabilly69 Posted February 14 Posted February 14 This might be a little off course, but if you are looking for low output style PAFs, check out the Duncan Jazz pickup in both neck and bridge, I was taken a back at how good these pickups sounded. A realsleeper set! I liked them better than the Seths and 59's! Great clarity in the neck, and the bridge was perfect for on the edge of distortion sounds with a great mid honk. Here's a set plugged right into my Marshall... 1
MartyGrass Posted February 15 Posted February 15 One thing is a clear difference. Tap the cover of a Seth and you will hear a click. No wax. Not a big deal. 1
nuke Posted February 18 Author Posted February 18 (edited) Well, I scored a used set of 2016 Seth Lovers on FleaBay, reasonable price and already patina'd and "pre-aged" from natural wear and tear, so they look right in this workhorse guitar with its own natural wear and tear. The harshness I heard with the stock 59's is reduced, the Seth Lovers are more bell-like, clear, and I think a step in the right direction for me anyway. I took measurements of inductance and capacitance at 120hz, DCR, and magnetic field strength while they were out. SD-59 Bridge: 5.016 H, 350nF Cs, 59.47 nF Cp, DCR 8.27k, field 40mt at the top screws. SD-59 Neck: 4.191 H, 419.6 nF Cs, 65.84 nF Cp, DCR 7.236k, field 40mt at the top screws. Seth Lover Bridge: 4.76 H, 369.6 nF Cs, 58 nF Cp, DCR 8.202k, field 37mt at the top screws. Seth Lover Neck: 4.00 H, 438.7 nF Cs, 58.84 nF Cs, DCR7.59kk, field 37mt at the top screws. I compared the Seth Lovers now installed in my 1998 H150, with Faber hardware and lightweight locking Gotoh tuners, against my Gibson Custom Shop R0, 60th anniversary edition, with its stock Custom Bucker III pickups in it, unpotted like the Seth Lovers. Both have 50's wiring, paper-in-oil caps. The biggest difference is weight, the H150 being 8lbs and 13oz, the Gibson Les Paul is a svelte 8lbs, 1oz. (not chambered). The Gibson is more lush, with a bit more overtones, the neck being on the dark side and the bridge having a good bit more brightness and snap. It does that, "beefy telecaster" thing. Though both pickups are the same in the set. The H150 with Seths is more forward sounding, brighter, punchy, but doesn't have the same rich overtones as the Gibson. They're quite distinctly different sounding guitars, in spite of their close similarities. Both have the pickups set to the exact same height, both wearing pure nickel strings. With nearly a pound of weight difference between them (about 13oz) I wonder how much is wood and how much is pickups. Edited February 18 by nuke 2
rockabilly69 Posted February 19 Posted February 19 On 2/18/2026 at 12:01 AM, nuke said: I wonder how much is wood and how much is pickups. You could always swap the pickups in the H150 and the LP and see if the tone follows the pickups, then you'll know the answer to that What do I think? Because those pickups aren't potted, I think it's the wood.
nuke Posted February 21 Author Posted February 21 Yeah it’s weird. The Gibson Custom Buckers 3 are un-potted just like the Seth Lovers. The Custom Buckers have alnico III magnets. I decided to take electrical measurements of the Custom Buckers 3. The neck and bridge exactly the same in the set. They measure up at 4.4H inductance and about 7.4k. I will chalk it up to alnico 3, versus the Lovers with alnico 2 and the 59’s with alnico 5. I’ll check the magnetic field too for comparison. Just didn’t have the gauss meter out.
JeffB Posted February 21 Posted February 21 (edited) When I got my H150 I thought it had Seths in it. It didnt, it had 59s. I cant remember why I thought they were seth's. I loved the sounds I got out of the guitar, cleans, low gain, high gain, neck or bridge. I talked about Seths as though they were the best things. After a few years I found out they were 59s....lol. So I swapped them for seths. Didnt like the guitar so much after that, played it less. Eventually I put the 59s back in and joy was restored. Then I temporarily swapped the guitar with a friend for a gibson R59. When we traded our guitars back to each other the SD 59s were in the case and it had SD antiquities and new potentiometers. He thought he was giving me a gift, a nice surprise. He is a lovely guy, a good friend, he meant well... it had lost some of the immediate rocknroll crack and snap, there was a lazy fizz and ear fatiguing boxy mid honk. It lost some the sweetness and clarity when played through a clean amp. It had lost chug and that deep percussive "thunk" That was 10yrs ago, the SD antiquities are still in it. I never got around to putting it back to original. Sounds great, its a really good sounding guitar. Some where during that 10yrs the pick ups just conformed to my expectations and developed all the traits I liked of the SD59s. Edited February 21 by JeffB 1
les paulverizer Posted March 10 Posted March 10 My 30-something yrs old H150 came with Schaller pup's, "Golden 50s" I think, which I swapped for Seymour Duncan Antiquities, the a SD '59 in the neck, then I put a first production Gibson '57+ (the Tom Holmes ones!) and it always sounded wonderful. Not for nothing it's called a pick-up, after all the acoustic sound of the guitar is what every pickup has as the basis for the sound it will eventually produce, unless one goes through extreme processing, then the guitar becomes "almost" irrelevant because 99% of what we hear is the effects: Anyway, few years ago I fitted a set of OX4 "Beano" pups on my H150 (I also have a set of OX4 "Jimmy Page" on my Gibson '58 Reissue) and oh my God, who ever said that perfection is not of this world has never tried this combo! It's just "that" sound and it has everything, sustain, thick while extremely dynamic, sensitive to the touch and changes in Volume or Tone controls on the guitar, a perfect EQ with just the right balance of bass - mids & treble....as I said perfect, and these are the only pups that hit me like that, love at first chord. I have to say that I tend to go for a very simple set up guitar - 1 or 2 pedals - Marshall on crunch, however I am a professional musicians hance at time I h=found myself playing though elaborate set up, both live and in the studio (I used this guitar straight to the console when laying down parts for a Netflix soundtrack...) nevertheless the results have never been short of impressive! That's my experience anyway... 2
DetroitBlues Posted March 11 Posted March 11 One thing I should mention... Most often the use of tone and volume controls really make a difference. Seldom do I now have my volume or tone control all the way up. On the occasion I find I'm not cutting through, I max the tone. I have a Red Rocks Alnico III in my H535's bridge position, Seth Lover in my H140's bridge position, and a SD '59 in my H150 bridge position. What I can tell you, with all three of them, I can dial them in, swap them out in a gig or a song, and they will sound very close to each other; especially in the context of a mix. And I have no idea what clean means, who plays clean unless you're in a Jazz trio? Even playing a slow tune, my amp gain is there, just with the volume rolled back to "clean" it up....
nuke Posted March 13 Author Posted March 13 (edited) Well after some time playing the Seth Lovers, I'm a bit on the fence. They're less aggressive than the SD59's, but perhaps a little more in the bright and clear direction than I was thinking. I like them pretty well for the most part, and that tinge of harsh the SD59's I didn't care for is gone. I play pretty simple rig, just amp on the edge of break up, run the volume up and down for dynamics and adjust the tone on the guitar as I'm playing. I was pleasantly surprised how well the bridge does with some gain going on the amp, while the neck cleans up easy with some volume roll off without getting too dark. (50's wiring in my guitar, so it doesn't get dark as the volume rolls off). I'm thinking about trying a magnet swap in the Custom Bucker III p'ups in the Custom Shop Gibson R0. I already have a pair of Alnico 2 magnets on hand. Just trying to decide if it is worth the trouble. On the other hand, got to play a Custom Shop Gibson R9 (59 reissue) that the owner put a set of ThroBaks in as well as hear him play it a bunch. Holy smokes, that guitar sounds good, and he's a great player to boot. I also played a Collings I35LC (335-ish) with factory-installed ThroBaks not too long ago, that was fantastic. My H535 is a 2001 with HRW's in it and I wouldn't change a thing on it. Edited March 13 by nuke
Register a new accountSign in
