JeffB Posted May 18 Posted May 18 Put this board together over the last few days. Pretty much my old gig board with similar pedals. I used to have two timmy's, one on all the time slightly above unity with my amp. I will give the Duke of tone a good try as a replacement for the second timmy. The Jetter Red2 is rock and swamp and each works out as a solo boost for the other. Red is Marshall and blue goes from transparent to thick and swampy. MS3 is trem, delay, etc. I used to have two DD7s 105-120ms/350-400ms. I can do this on the MS3. The only other pedal I used was a trem pedal. The MS3 as delay and mods should work out fine. I used to use it as a switcher and fx controller. What you got? 4
Steiner Posted May 19 Posted May 19 I have a Strymon Time. I’d love to brag but I only use 1 of the 12,382 settings. i see you saved room on your board for a Klon. Nice… 1
JeffB Posted May 23 Author Posted May 23 The title included "...so far" The Duke of Tone is redundant. I did have the Prince of Tone back in 2012-13, I didnt like it and sold it. 13-14yrs later I couldnt remember why I didnt like it so I bought the Duke of Tone. This time around, I dont dislike it, it just isnt what I want. The Red2 although a different circuit and intent fills the spot much better...and that sparked the memory of why I sold the Prince of Tone back then, it was because I bought and used the Red2. Still doing circles.
JeffB Posted June 19 Author Posted June 19 On 5/23/2026 at 3:01 PM, JeffB said: The title included "...so far" The Duke of Tone is redundant... I dont dislike it, it just isnt what I want. The Red2 although a different circuit and intent fills the spot much better... 27 days later: I like the Duke of tone pedal! It displaced the Jetter Red2. 1
Gitterman Posted August 25 Posted August 25 On 6/19/2026 at 9:09 AM, JeffB said: 27 days later: I like the Duke of tone pedal! It displaced the Jetter Red2. lol 1 1
JeffB Posted August 26 Author Posted August 26 (edited) On 8/25/2026 at 10:03 AM, Gitterman said: lol Well, I posted that 68days ago. Since then: Duke of Tone displaced Jetter Red2... but then, the DoT was displaced by a MXR timmy and two Danelectro Timmy clones, 3 timmy's!!!... and also an on all the time Line 6 Constrictor set to the mellow/LA-2A setting Rest of the board is EQD sea machine and 2x delay (short analogue, long digital) Its not the finished thing, but it is finished for today. Edited August 26 by JeffB
RJLII Posted August 27 Posted August 27 (edited) On 8/26/2026 at 7:26 AM, JeffB said: Well, I posted that 68days ago. Since then: Duke of Tone displaced Jetter Red2... but then, the DoT was displaced by a MXR timmy and two Danelectro Timmy clones, 3 timmy's!!!... and also an on all the time Line 6 Constrictor set to the mellow/LA-2A setting Rest of the board is EQD sea machine and 2x delay (short analogue, long digital) Its not the finished thing, but it is finished for today. I like the redundant boost approach. I use three. A Spark Mini as a clean boost or to raise my Fenders up to the same level as my humbucker equipped guitars. An RC Booster for light gain and sparkle, and a Timmy for heavier gain. They all stack well too. I may add another Spark Mini after the Timmy as a dirty boost. Edited August 27 by RJLII 1
rockabilly69 Posted September 2 Posted September 2 My band pedalboard has 3 drives and a fuzz! Origin Effects Revival Druve Custom - my basic tone always on!!! Origin Effects MidEQ Driver - adds thicker mids and gain for solos! Sex Drive - Clean Boost when I need it to punch through! Analog Man BC108 Sunface - for Fuzz - for getting fuzzy! 1 1
DetroitBlues Posted September 3 Posted September 3 (edited) While I have a pair of Timmy's, I only use one at the moment. I use my Digitech Bad Monkey as my solo boost through an effects loop, only works on my Peavey, it doesn't work on my Marshall. I will try it out on my Kendrick this weekend. Here's the flow: Front of Amp: Boss WL-60 > Dunlop Wah > Boss TU-3 > Xotic Compressor > Wampler Terraform (pre-effects loop side) > Timmy v3 > Amp Input Effects Loop: Joyo Gate of Khan (Noise Suppressor) > Wampler Terraform (effects loop) > UA Del-Verb > Digitech Bad Monkey Edited September 3 by DetroitBlues
DetroitBlues Posted September 3 Posted September 3 On 5/18/2026 at 2:45 AM, JeffB said: Put this board together over the last few days. Pretty much my old gig board with similar pedals. I used to have two timmy's, one on all the time slightly above unity with my amp. I will give the Duke of tone a good try as a replacement for the second timmy. The Jetter Red2 is rock and swamp and each works out as a solo boost for the other. Red is Marshall and blue goes from transparent to thick and swampy. MS3 is trem, delay, etc. I used to have two DD7s 105-120ms/350-400ms. I can do this on the MS3. The only other pedal I used was a trem pedal. The MS3 as delay and mods should work out fine. I used to use it as a switcher and fx controller. What you got? I tried one of those Boss units for a hot minute and found it too confusing to run the way I wanted it to.
JeffB Posted September 4 Author Posted September 4 19 hours ago, DetroitBlues said: I tried one of those Boss units for a hot minute and found it too confusing to run the way I wanted it to. Ive had boss and other brands multi fx units since the late 80s. Around 2012-14 I had both Kemper and fractal gear. Ive kind of just been around the technology as it evolved through 80s-2018 and Ive just gone with it. The MS3 and a TC electronic Modulator is all I have remaining as far as digital multi FX goes. I bought the MS3 in 2018, I barely used it.
TalismanRich Posted September 4 Posted September 4 I've got a Digitech RP355 that I picked up years ago. I thought it would be nice to simplify things and just have one pedal. I played with it for a month or two, and it went over to the corner. Occasionally I'll give it another shot, and I soon get frustrated and move on. The old PodXT was better. As much of a pain as it is to transport it, I still like my individual pedals. 1
JeffB Posted September 4 Author Posted September 4 1 hour ago, TalismanRich said: I've got a Digitech RP355 that I picked up years ago. I thought it would be nice to simplify things and just have one pedal. I played with it for a month or two, and it went over to the corner. Occasionally I'll give it another shot, and I soon get frustrated and move on. The old PodXT was better. As much of a pain as it is to transport it, I still like my individual pedals. I gigged the PodXTlive for a while. Ive mostly used individual pedals, a few ods, a modulation and two delay pedals. Variations on that.
JeffB Posted September 4 Author Posted September 4 On 9/2/2026 at 10:46 AM, rockabilly69 said: My band pedalboard has 3 drives and a fuzz! Origin Effects Revival Druve Custom - my basic tone always on!!! Origin Effects MidEQ Driver - adds thicker mids and gain for solos! Sex Drive - Clean Boost when I need it to punch through! Analog Man BC108 Sunface - for Fuzz - for getting fuzzy! On 9/3/2026 at 10:29 PM, DetroitBlues said: While I have a pair of Timmy's, I only use one at the moment. I use my Digitech Bad Monkey as my solo boost through an effects loop, only works on my Peavey, it doesn't work on my Marshall. I will try it out on my Kendrick this weekend. Here's the flow: Front of Amp: Boss WL-60 > Dunlop Wah > Boss TU-3 > Xotic Compressor > Wampler Terraform (pre-effects loop side) > Timmy v3 > Amp Input Effects Loop: Joyo Gate of Khan (Noise Suppressor) > Wampler Terraform (effects loop) > UA Del-Verb > Digitech Bad Monkey There are pedals on both of these boards I would like to spend time with. So much cool stuff.
rockabilly69 Posted September 4 Posted September 4 (edited) 2 hours ago, JeffB said: There are pedals on both of these boards I would like to spend time with. So much cool stuff. The three pedals on my board that are the most important are the Revival Drive, which is my core tone, the MEQdriver, which is my lead tone, and the Space Echo which is always on and beat timed to the song I'm playing. The rest of the stuff (other than the tuner of course) is just icing on the cake. I only use trem and reverb on one or two songs a night. And the Sunface, an excellent fuzz, doesn't really get the use since I got the MEQdriver. And I don't really need the sex drive if I have time to dial in the two other gain pedals for the venue I'm playing in. And actually I could get away without the MEQ driver if I have time to dial in both sides of the Revival Drive, because it has variable mid boost, but the MEQ driver is easier to dial in my lead tone with on stage. Frankly I was always a plug straight in to the amp kind of player but this band of mine covers a lot of different tones in the songs I write, so having the pedals makes it bit easier because I'm not having to tweak the amp from song to song. When I record the song demos though, I almost never use pedals. It's just an amp, and an attenuator if I'm recording at night. I almost always prefer that tone to pedals. Edited September 4 by rockabilly69 1
DetroitBlues Posted September 16 Posted September 16 In the midst of going back and revising the board for a simple method of running everything to the front of the amp and forgo the effects loop. At the same time, I am also adding in a volume pedal as it is something I've been wanting to add and with a possibility of a being in a tribute band that covers Stevie Nicks Fleetwood Mac music. Lots of ambient guitar parts Lindsey Buckingham plays that calls for some additional effects.
JeffB Posted September 16 Author Posted September 16 Because Im going to be a shredder <laughs out loud and startles the cat> Ive been looking at high gain od/dist pedals even though in a post somewhere else I dont really like high gain. I found some snug fitting spandex pants. I feel like the whole shred idea thing is moving along nicely.
PunkKitty Posted September 16 Posted September 16 (edited) If I used analog effects, I would need a 3' x 4' pedal board. So I had to go digital. I bought a Boss GX-10 and it worked well. But it was confusing. On a whim, I bought a Soran Tiny Stomp from Amazon for $50. It has 125 effects and more amp modeling than I need. It also has a built-in looper and drum machine. It sounds really good. It's much easier to use. I can use an external expression pedal for wah or volume. I program in the set list, and just go down the list of songs. And the Bluetooth actually works with my cell phone so I can make changes on the fly. It's about the size of 2 packs of cigarettes and has a built-in rechargeable battery. It's worth buying one just to screw around with. The same unit is marketed under a few different brand names. I'm never going back to analog. And I sold the GX-10. Edited September 16 by PunkKitty 1
DetroitBlues Posted September 17 Posted September 17 (edited) I was going to add a volume pedal to my board... The interwebs recommended to find a used Boss FV-500H. So I bought a used one.... However, this beast of a pedal is about 20% bigger than a standard WAH pedal... Not sure what Boss was thinking making such an oversized pedal... Not sure who they think is supposed to be using this.... wowzers. Edited September 17 by DetroitBlues
JeffB Posted September 17 Author Posted September 17 2 hours ago, DetroitBlues said: I was going to add a volume pedal to my board... The interwebs recommended to find a used Boss FV-500H. So I bought a used one.... However, this beast of a pedal is about 20% bigger than a standard WAH pedal... Not sure what Boss was thinking making such an oversized pedal... Not sure who they think is supposed to be using this.... wowzers. Yeah, that is a weapon.
rockabilly69 Posted September 17 Posted September 17 7 hours ago, DetroitBlues said: I was going to add a volume pedal to my board... The interwebs recommended to find a used Boss FV-500H. So I bought a used one.... However, this beast of a pedal is about 20% bigger than a standard WAH pedal... Not sure what Boss was thinking making such an oversized pedal... Not sure who they think is supposed to be using this.... wowzers. Looks like something a pedal steel player would love. The bigger they are the smoother they usually are for minute adjustments. Funny thing I just bought a minature volume pedal from a pedal steel guy It's called a Moyo, and it's built very well. It uses a 250K Dunlop Super Pot. I bought it for a small acoustic board that I put together.
DetroitBlues Posted September 17 Posted September 17 1 hour ago, rockabilly69 said: Looks like something a pedal steel player would love. The bigger they are the smoother they usually are for minute adjustments. Funny thing I just bought a minature volume pedal from a pedal steel guy It's called a Moyo, and it's built very well. It uses a 250K Dunlop Super Pot. I bought it for a small acoustic board that I put together. That's interesting. I was rather surprised to see after years and years, manufactures still employ a string to turn the volume pot instead of a treadle like a Wah pedal....
rockabilly69 Posted September 17 Posted September 17 (edited) 9 minutes ago, DetroitBlues said: That's interesting. I was rather surprised to see after years and years, manufactures still employ a string to turn the volume pot instead of a treadle like a Wah pedal.... The Ernie Ball Volume Pedal Jr is still my favorite volume pedal for feel, and it's a string, which I had to replace once and that was a bitch... Edited September 17 by rockabilly69
rockabilly69 Posted September 18 Posted September 18 Tonight‘s rearrangement of the pedals in the next few days, I may swap out my tremolo and echo for slightly smaller versions of the same thing. 1 1
rockabilly69 Posted September 18 Posted September 18 I'm going to try a Demeter Tremulator for a simpler and smaller 2 button tremolo. I only use tremolo on two songs, and neither song requires anything more than a good amp like trem. And that's where the Tremulator shines. My brother had one in his studio, I used it on a few songs, and it sounded great. https://demeteramps.com/product/trm-1-tremulator/ Next I'm going to audition the NuX NDD-7 Tape Echo, which is kind of similiar to my Space Echo but smaller, lighter, and easier to adjust on the fly. It gets great reviews. One thing I like, is that you can make deeper adjustments (saturation, wow, flutter, etc) using a computer and it's PC/Mac editor, the kind of adjustments I wouldn't want want to do on stage. https://www.nux.us/products/tape-echo?srsltid=AU7gw4XKnxvRRFVV_Hr6FDB6psS7mBdNJ7RSCa3zRtv9BGufVSiQkJhm 1
Register a new accountSign in
