Well, PSP got a little spendy for me . . . bought the pictured 535 standard (with same OSB finish as TRich's new 530).
Point 1: I'm trying to recreate the tone as heard on a couple of Doobie Brothers songs, South City Midnight Lady and Another Park, Another Sunday.
My best guess is that the guitar played on those songs is a G 335. Can anyone confirm this?
Point 2: If the guitar is a 335, how can I get my new 535 to sound like this? SD 59s are in the new axe and I haven't been able to get the tone I seek. I see mixed reviews of the 59s here on HOC and I wonder if Seth Lovers would get me closer? Or, just change the magnets in the 59s to alnico 2 or 3? Or . . . ?
Comments and insights most appreciated! Thanks, eljay
  • Like 1
Usually Pat Simmons is playing an acoustic and Tom Johnstons's primary guitars have been PRS for many years.
Back in the mid 70s,  Pat would often play a sunburst ES345 but the Varitone was disconnected.  He also had a natural finish ES345 with gold hardware in 74.  He  had a red ES335 that he sometimes tuned to DADDAD.  As to what he played on any particular record, it's hard to say.
Tom Johnston had a couple of Les Pauls,  a black Custom w/ a Bigsby and a gold top w/P90s.  I've seen some videos  with him playing an SG.  He also played a 335 on occasion in the early days of the Doobies.
For South City Midnight Lady,  Pat was probably playing his Ovation acoustic.  Skunk Baxter was playing steel guitar.   Don't know what Tom was playing, but I read that Pat did solos on his 335.
From the concert photos I've seen, they mostly had Fender amps.
Something else to remember is that Pat will quite often fingerpick his electrics.   That's going to give a different sound that using a pick.
Here's a shot of Tom Johnston playing an ES-150 on Midnight Special.
Very informative, Rich, thanks kindly!
  • Like 1
I think he was using Heritage Custom Shop 225s......
  • Like 1
Thinking about the pickups,  if the guitars were late 60s or early 70s, they probably had Gibson T-Tops.   Guys like Seymour Duncan and Larry Dimarzio didn't really start making after market pups until around 72 or 73.
As to how they were made,  according to this article, they would be Alnico 5 with polyurethane coated wire ~7.5 ohms.  That's pretty much the SD-59 recipe, isn't it.
https://musicalilluminism.wordpress.com/2009/04/28/vintage-gibson-humbucker-specs-and-general-pickup-tech/
  • Like 1
Most of their sounds are pretty Fender sounding, and since they formed in California, most likely Fenders and modded fenders were the weapons of choice, with relatively low levels of overdrive. Some googling brings up things like a Fender Twin and a Marshall JMP, and listening to a lot of their stuff just makes me think "tweed".
There are some really nice tweed pedals out there, both analog and modeling, and might be best to look into those before going down the pickup rabbit hole. '59 pickups should be able to do Doobie brothers stuff just fine.
Update, I fiddled around with pickup selection and tone controls and found that the neck pup only and treble rolled way down yield tone similar to what I've been after. Progress made! Also must consider the possibility that effects pedal is in the mix. I'm playing straight into the amp with just a bit of reverb dialed up.
I heard it at the VFW and was quite impressed! I've scrounged up my MXR equalizer and will mess with it and the 535.
I've sort of stopped chasing down tones in my head and chasing tones in my ears.  I went down the rabbit hole for tone quests and found that tone in a room sounds different than tone on a recording.  Pickups, guitars, strings, amps, speakers, microphones, where you pick the strings, how you pick the strings, post preamp equalization.... its maddening when you start to dig into it.  I've only changed pickups in recent years for noise and feedback reduction.
I think you'd be amazed how that beautiful H535 sounds depending on the amp and the use of the tone controls.  I really love the middle position, I turn the volume on the bridge pickup to around a 7 or 8, roll back the tone to an 8.  Then on the neck position, I'll roll the volume back just a touch at a time until it just adds a bit of warmth to the bridge pickup, usually it ends up around 6-7.   When I need a bit for a lead solo, I'll go to the bridge and sometimes raise the volume up a bit.  All this is accomplished to get a tone that I can clearly hear against the band and sounds good to me.  I stopped chasing my hero's tones and just play to the song.
One of my favorite tunes lately is Marshall Tucker's Can't You See.  I'll play the flute and the lead guitar tracks with any of my guitars; by adjusting the controls I can make any of them sound pretty close to each other and they all have different pickups.... H150 with SD 59's, H137 with Mojotone Quiet Coil P90's, H535 with a Railhammer Neuvo in the neck and a Red Rock A3 humbucker in the bridge.  I can use any of those guitars and achieve a tone that sounds good to me even if there is a slight difference in sound.  Audiences don't know the difference.
In other words, don't get too caught up yet on pickup being a problem, there is a lot more to the signal chain besides the pickups.
Thanks, Josh, I appreciate your input
I’m reading this and agreeing with all.  The irony is when I try to describe high-gain guitar to guitar muggles, I use Doobies’ China Grove as an example.  I additionally dime the gain to play Without You.  The brown Fender in TR’s picture above looks to be the same one Ronnie Montrose used on his first album.
The songs you’re approaching eljay are cleanish that can be approached by lowering amp gain levels together with guitar volume.  And as far as the NGD goes:  Nice Snatch!
On 8/11/2025 at 12:53 PM, TalismanRich said:
There's a cool little blue pedal that you can plug into and get a really nice "woman tone".   Pete Farmer loaned me his pedal for PSP.
. . . and so I bought one! arrived last evening . . . gonna mess with it today . . .
After playing through that one,  I'm tempted to replace my old TS-9 Tube Screamer.   I listened to a few comparisons of the Blues Driver vs Tube Screamer, and I think the Boss is more the sound I am looking for.
  • 2 months later...
Quest is ovah, found the sound! Wolfetone Legends in 535 I bought used from Dave's. Neck pickup with tone rolled all the way down.
A-B'd with the 535 (Duncan 59s) I purchased at PSP. Noticeable difference . . .
  • Like 2
A very young bass player once bought a Rickenbacker bass, in the footsteps of his hero, Chris Squire.  He was most disappointed to find that he didn't sound at all like Chris Squire. The young bass player eventually became quite famous on his own and associated closely with the Rickenbacker bass.
Thing is changing parts will make little tweaks in the sound, but you might be chasing a ghost. We don't really know what instrument might have been played in a studio, even when a musician is strongly associated with a particular instrument. Sometimes, maybe there was just something random in the place and he picked it up and played it. Then there's the amp, and the micing and the room, and the engineer's technique to take the track, that particular session or maybe many sessions and so on and so forth.
Find the guitar that works for you and your hands, and play the song(s) you want as well as possible. Then, record it. Compare overlayed on the track you want to sound like. See what you can do with various studio/DAW plugins, especially ones that represent the things that might have been in use at the time it was originally recorded. Then do some deducing what is and isn't close to your ghost. In many cases you can get "there" with some EQ, compression and creative dialing in of those.
  • Like 1
15 hours ago, nuke said:
A very young bass player once bought a Rickenbacker bass, in the footsteps of his hero, Chris Squire.  He was most disappointed to find that he didn't sound at all like Chris Squire. The young bass player eventually became quite famous on his own and associated closely with the Rickenbacker.
You left out that the young bass player played in his hero’s band the last time Anderson, Wakeman and Howe were together on stage.  He did so, most notably, with a Fender bass…
https://www.yout-ube.com/watch?v=8_hAhzdk-h8&list=RD8_hAhzdk-h8&start_radio=1
18 hours ago, bolero said:
I have Wolfetone Legends in my H-535
and you and I are well set on the H-535 front! I bought a pair of the Legends' cousin, the Dr. Vintage, thinking I'd install them in a Gibson LP Studio. However, the LP sounds too goo to mess with so methinks the 59s in the new 535 will get 86'd and replaced with the Dr. Vs. I guess I've become a Wolfetone fanboi . . .
  • Like 1
Yeah, I'm a big fan. I have a USA Geddy Lee signature model. I really love it too! And a Rick 4003. Black, of course.
(couldn't live with the old Rick bridge - neither did Geddy, as he put a BaddAss bridge on it.
  • Like 1
Saw him play in ‘78.  Until that point I had no idea there were only 3 dudes making all that sound!  Good times…
  • Like 1
I transplanted the Wolfetones into my 535 from my H150, then bought another set of Wolfe's for the H150 🤣
I can't remember what was originally in the 535, maybe Duncan 59's?
I’ve got a 2001 535 with the HRW’s in it. Like it very much. I put a Faber bridge and tailpiece on it, mostly for feel since I’m used to a tune-o-matic under my muting hand.
I later put in the Faber bushings and was amazed at how much the tailpiece bushing inserts changed the tone. Made really good even better. They go much deeper and firmer into the maple center block, seem to acoustically couple to the wood much better than the much shorter and looser Schaller hardware.
The HRW pickups are very amenable to tone shaping with the amp or pedals and EQ. Can dial in a variety of tones from them very easily. Some say they are “hi fi” but I’d say smooth frequency response curve. Which is ideal for dialing the amp/effects to get a sound.
I’d say exhaust all the external tone shaping options before you change parts. A 7 or 10-band EQ can be very helpful to figure out what to do to get where you want to go.
  • Like 1
I'm also a fan of Wolfetones. I've got Legends in one Zemaitis, Legend and a Fenris in another, Dr V and a Marshallhead in a  PRS Custom 22, and a Mean and Meaner P90 set in my SG Special!
  • Like 1
